blazer catalytic converter
hello i have an 2000 chevy blazer 4 door . the catalytic converter is bad and broken in side so it rattle badly . can i remove it put a straight pipe in it place or with that throw the motor off with the exhaust senors and check enigne light on . any info with help thanks
We are not able to help you with removal of your cat, Replace it with a new one. Its against federal law to not have one.
Like said it is ilegal to run without Period
Removal of the cat will not fix the check engine light issue so if your area requires emission testing ,it is usually an automatic fail if the light is on You can buy yourself an aftermarket cat. for a reasonable price |
All we can say, is that there is alot of poeple with no cats on their trucks. How they run, we dont know. Google could help you out with your question, but for the love of everyone on earth, please run a cat convertor on your truck.
Originally Posted by ohsofly
(Post 582214)
Just replace the cat, straight pipe would require o2 simulators, jegs, Summit Racing... I however chose to replace mine with a magnaflow piece..
| All times are GMT -5. The time now is 09:18 AM. |
