Blazer Operating Temperature
When I drive my Blazer without the air conditioning running it runs at 193 degrees. If I turn on the AC it will run between 197 - 198 degrees.
What temperature does your Blazer run at under these conditions?
Mine is usually around the 203F mark on a hot day. That's with the 2 - 1730cfm E fans on the shroud I made at work & a 180F thermostat. Keep in mind that mine does run a little warmer due to the supercharger.
