-   General Chat (https://blazerforum.com/forum/general-chat-34/)
-   -   Changed Calipers And..... (https://blazerforum.com/forum/general-chat-34/changed-calipers-86200/)
99TrailblazerConway 06-18-2014 04:20 PM
So i had some issues came to the conclusion i should change my calipers since i felt like they were sticking.
I jacked my truck up tried to spin the left front tire had resistance changed the caliper tried to spin my tire had no resistance fixed it right up.. So did the same thing with my front right jacked it up tried to spin it had resistance changed the caliper BUT is still has the resistance in it. From what people say only thing that can make your tire not spin is that caliper sticking. Any input?
99TrailblazerConway 06-18-2014 05:44 PM
Anyone?
TripleBlackBlazer 06-18-2014 05:50 PM
Wheel bearings? While it's jacked up, grab the wheel at 12 and 6 and try to rock it up and down. Movement or clunking usually indicates a bad wheel bearing.
99TrailblazerConway 06-18-2014 05:59 PM
Thank You
rexazz2 06-18-2014 06:16 PM
collapsed flex hose
if you can open the bleeder screw and the resistance goes away you are holding fluid pressure somewhere
