Changing Spark Plugs ?
Old Jul 15, 2023 | 09:58 AM
lathechips's Avatar
lathechips is on a distinguished road
Default Changing Spark Plugs ?
03, 4wd, V6, Any advice on changing spark plugs?
Old Jul 15, 2023 | 01:57 PM
A few random thoughts:
  • The one in the middle on the driver's side is notorious for being hard to get out. There has been a special Snap-On socket for it but most of us McGyver a solution. I think installed a spark plug socket and used a wrench on it.
  • They should only need to be replaced every 100k miles. As such, replace them with good quality ones. I used OEM ones.
  • You might also replace the spark plug wires, and the rotor and distributor cap while you are at it. General consensus is to only use AC-Delco caps and rotors.
Old Jul 16, 2023 | 08:20 AM
Stovey's Avatar
Stovey will become famous soon enough
Take a look at this thread:
https://blazerforum.com/forum/tech-a...ilation-40425/
Access to the spark plugs is easier through the wheel wells. So the front end should be raised and the wheels removed. I found it easiest to access Spark Plug #2 (front passenger side) from the engine bay with a slim ratchet.
I installed ACDelco 41-993 iridium plugs. The gap is pre-set, but you might want to double check the gap before installation. Be careful not to drop the plugs on the concrete floor.
ddellisanti
Jun 24, 2023 03:57 PM
TheSaint
Sep 7, 2016 08:12 AM
vze4yrte
Mar 23, 2010 06:46 AM
speeddemon560
Engine & Internal
Jan 12, 2007 10:36 PM
thorbergdt
Engine & Internal
Jan 5, 2005 10:02 PM
