Chevy Blazer Starting and Stalling Problems
Old Aug 11, 2009 | 03:42 AM
andrewmoquin's Avatar
andrewmoquin is on a distinguished road
Default Chevy Blazer Starting and Stalling Problems
My blazer wont start unless I spray carb cleaner in the carb.I've read that u need 60 psi to start but mine only has 50 to 55 key on engine off.It has a new fuel filter so dose that mean I just need to replace the pump? btw once I get it started it runs fine and useully will start again but not after sitting all night.
Please help. It would be greatly appreciated. Thanks a lot!
-Andy
Old Aug 24, 2009 | 05:28 AM
ben512v's Avatar
ben512v is on a distinguished road
check the spark on the plugs remove a wire put a old plug in the end of the wire and have someone turn the engine over you should have a pretty blue spark not a yellow one blue is a strong fire spark and yellow is a weak one this will help narrow it down also the pump should have a constant pressure with no leak downs leave the gage on and in the morning see if it leaked down the pump may be bad like you suggested.
chinbin
Feb 25, 2015 12:03 PM
TxSheriff
May 7, 2014 05:50 PM
ericthughes
Dec 19, 2010 07:00 PM
jackiemodica
Jul 23, 2010 02:59 PM
dragonsdeath
Oct 7, 2006 01:08 AM
