Custom Lift Or Lower?
hey i was wondering if there's anyway to customly lower my blazer i know if i tighten my torsion keys it will lower the front but then i want to lower the back and i dont wanna spend money "so is there anyway to customly lower it?
and same goes it if wanted to lift it i could just tighten the torsion keys to lift the front but then how can i customly lift the back? thanks for any replys, cory.http://www.oldsmobileforums.com/foru...lies/smile.gif |
To lift the front you tighten the keys, to lower you lower the keys.
In the rear to lift you can add shackles. To lower, use drop blocks that go between your axle and leaf spring. |
okay thanks now do i have to buy any of that cause i dont hav money haha so im trying to customly do it.
OK. How are you going to do it "customly" without money to buy supplies? There is no way to do it without parts.
lift shackles or lowering blocks dont cost more then 100 bucks
you can find them on ebay |
is there anything you can adjust in the back, to lower it or anything?
nope there is no adjustments in the rear
Technically you really need an alignment when altering the front height, so there really aren't any "free" ways of raising OR lowering your truck. Cheap ways, sure, but not free.
Sounds like you need to customly leave it alone until you can afford to do it right. Raising or lowering the front is gonna require an alignment or you will waste the front tires.
There is one way to lower it for free, just drop the pressure in all four tires to about 5-8 psi.
Not recommend,though. What is highly recommed is to get a job that will allow you to "customly" modify your ride the way you like. |
| All times are GMT -5. The time now is 04:33 PM. |
