-   General Chat (https://blazerforum.com/forum/general-chat-34/)
-   -   firewall question (https://blazerforum.com/forum/general-chat-34/firewall-question-46873/)
carlosg7915 Jul 16, 2010 03:54 PM
firewall question
Im trying to run a battery wire thru the firewall. anybody know where the hole is to run the wire?
DKSDAD Jul 16, 2010 10:42 PM
You will probably have to make your own or if it will fit check to see if you can pass it through the opening for the steering column.
chiefum Jul 17, 2010 10:21 AM
If you make a hole......I would use a rubber grommet.
carlosg7915 Jul 17, 2010 11:27 AM
i guess i'l make one then. any suggestions where to make it? last thing i want is to break something
Outsydr Jul 17, 2010 12:56 PM
Personally I did away with factory antenna and replaced with an interior mounted amplified antenna (can't see it unless you know where it is and what to look for and the reception is WAY better than the factory exterior one) and used the factory antenna hole/grommet for mine, just a suggestion.
carlosg7915 Jul 19, 2010 11:14 AM
found it... its right under the rug on the passanger side, if anyone ask's.
