Front Mount Hitch Uses?
guys that cant back up a trailer use them
have seen winches mounted that way to be able to use front or rear
keep a eye on your temp gauge , don't want to block the air to the rad
Myself I would have tried to tuck it up and behind the tag holder , put the tag holder on a spring loaded hinge
I`ve also seen for winch mounts front or rear. Good idea really Hitch Receiver Mount for Winches
Not a fan of seeing that hanging down but that's my opinion only
Put one on mine a month ago, also a curt I painted it the same color as truck also not a fan of it not tucking but figuredid takean extra bottom plastic peace I have and camouflage it a littlefab workand some epoxy and I hope it work out. I got it for a wench/cargo hauler.
you could always keep a few tow straps in the back along with a reese hook adaptor. I've heard that the hooks are not super durable and another mounting point would spread it out. just in case you gotta pull someone out
A lot of guys set up a winch to be able to be mounted either front or rear, but I've read that the pin that would hold the winch into the receiver tube really isn't build to hold up to heavy-duty winching. Especially if you have a 12k lb winch, and a super stuck truck. It's advised to get two receiver tubes for winch mounting. It would probably be ok, anyway, though, but that's what I've read.
