-   General Chat (https://blazerforum.com/forum/general-chat-34/)
-   -   Fuel pump problem (https://blazerforum.com/forum/general-chat-34/fuel-pump-problem-79900/)
Westra5 Jun 17, 2013 01:07 PM
Fuel pump problem
Have problem with fuel pumps going out. 3since I got it 3 years ago. Most recently replaced about 4 months ago with AC Delco pump. 1996 S-10. Any ideas what might be causing them to malfunction so frequently? Could it be a relay problem or other electrical issue?
Toby Hanson Jun 17, 2013 05:19 PM
What brands were the first couple of pumps? If they were not AC Delco or Delphi then such failures are not unusual. The AC Delco/Delphi pumps seem to be the most robust.
ohsofly Jun 17, 2013 06:51 PM
Do you like to drive around with only $5 in the tank? Empty tanks take out fuel pumps real easy. The gas cools the pump, so empty tank equals poor cooling of the pump mechanism.
Keep the tank over 1/2 all the time and you will find that pumps dont go out on you.
Also, anything other than Delco/Delphi is a waste of your money.
Westra5 Jun 18, 2013 09:57 AM
First two were not AC Delco. Third one was. Usually fill up around half tank or just under.. Fuel gauge does not work properly.
chris015 Jun 18, 2013 02:37 PM
you wont have anymore issues with this last one since its ac delco. For whatever reason these trucks are so picky on pumps.
El_Beautor Jun 19, 2013 10:47 AM
Since it's only 4 months old, it should be covered under warranty at least. I'd guess you just got a bad one, unless you got some bad gas or something in your tank.
Westra5 Jun 19, 2013 03:00 PM
Mechanic tells me it's a fuel injector issue and not the fuel pump. Says it's injecting too much fuel at once.
