Full size 8" lift kit on a midsize ???
Old Nov 16, 2011 | 09:46 AM
91chevywt's Avatar
91chevywt is an unknown quantity at this point
I really meant 2.5" suspension lift + 3" body lift + 2" tire height increase = 7.5" ride height increase in theory. Only really 5" of lift
Old Nov 16, 2011 | 01:41 PM
89Recon's Avatar
89Recon is an unknown quantity at this point
still better than none
Old Nov 16, 2011 | 01:46 PM
ChevyBlazerChick's Avatar
You need to find out what gears you are running. In order to run 35s with no breakage you need 4.10 gear ratio. Your RPO code in your glovebox has to say GT5. If you have GT4, then you shouldn't go higher than 33s.
Old Nov 16, 2011 | 01:56 PM
89Recon's Avatar
ok so it has to say GT5 not GT4 I am going to go check that right now hopefully it is GT5 *fingers crossed*
Old Nov 16, 2011 | 02:02 PM
Yeah, I used to have 2.73 ratio... for some ungodly reason(Lower the gear ratio, better the gas miliage... but its a 4WD truck lol). And blew out my entire rear end from running 33s. So I upgraded to 3.73. Hopefully you still have your Glovebox codes unlike me... all the tags on my truck are faded as heck. And if they are faded you can try to look for the metal tag on your rear end that should have it stamped into it... unless it wasn't there like on mine. lol
Old Nov 16, 2011 | 02:06 PM
89Recon's Avatar
the only thing in my glove compartment is a service identification sticker and it has nothing with even GT4 let alone GT5 is it somewhere else in the glove box that I am missing?
Old Nov 16, 2011 | 02:12 PM
It should be on that sticker. Do you think you could take a picture of it and try to get it as in focus as possible? So I can help you find the number pertaining to your Ratio. I'm pretty sure it will be the only group starting with a G. You might have something different than what I listed.
Old Nov 16, 2011 | 04:39 PM
89Recon's Avatar
Yeah I can definitely take a photo of it as in focus as I can lol will probably post it later today thanks for your patience.
Blazedawg151
Apr 3, 2012 01:18 AM
blazinloud
Dec 1, 2010 04:56 PM
scott_wheels
Jan 25, 2010 11:40 AM
robert25119
Jan 5, 2010 01:35 AM
midnightmekanik
Oct 8, 2009 08:32 PM
