-   General Chat (https://blazerforum.com/forum/general-chat-34/)
-   -   Gas tank overflow leak after filling the tank normal? (https://blazerforum.com/forum/general-chat-34/gas-tank-overflow-leak-after-filling-tank-normal-82693/)
Smc Nov 13, 2013 12:20 AM
I am new to the blazer world I just got a 2000 blazer white and I went and filled the tank and topped it off a couple time past the first pump shut off so then gas poured out the top of my tank for a like 30 sec and stopped is this normal? Or do you guys know why it happened?
richphotos Nov 13, 2013 12:34 AM
umm... sounds like you over filled it.
Where did the fuel come out? the filler neck where you put the nozzle?
If so.. you over filled it. It does this to every car when you over fill.
Smc Nov 13, 2013 09:29 AM
no it didn't come out if the neck it came from the top of the tank i think from where the fuel lines run it was dark couldn't really see.exactly. a couple. people have talked about a evap system dowb there it could have came out if but idk I'm new to thus truck
odat Nov 14, 2013 04:46 PM
1 Attachment(s)
No leakage is not normal - Look for a hole in tank - rust spot ect. - unhooked lines or bad lines / vapor return, fuel return, vent line or the O ring under the sending unit/fuel pump - u might want too add this too your ride - i think it's a good idea too have one even with no leaks
