Heater Core/Dash
Ok:
I see some posts with heater core nightmares. On a 96 do you or don't you have to remove the dashboard and if so how do you go about that. I have all the bottom plastic out,radio, climate control controls, bezel around instrument panel etc... and all but 1 of the screws holding the heater core box. What next? HELP HELP HELP!! Thanks Scott |
RE: Heater Core/Dash
Scott, double posting is against the Forum rules. I gave you a link to follow in your original postregardingthis procedure. :)
Yes, double posting is against forum rules. Other post will be deleted and this post will be moved to the correct posting location (general tech-not chat). If you do not get an awnser,please bump the topic, do not post again with the same question. Thank you (you might want to try and use the search function to find an awnser)
