How do i reattach my rear view mirror
I have a 96 Chevy Blazer and the rear view mirror has come off how do I get it back on? I have tried to use the kits at the auto store and it did not work. Suggestions please!!! Thanks in advance
You'll probably have to chip away the old residue on the piece that goes on the window. Make sure it's good and clean. There is also a cleaner in the kit that is used to clean your inner windshield where the mirror mounts. Make sure you give the epoxy enough time to cure after applying the metal piece that the mirror mounts to.
I have no idea where you are located but if in the the cold like I am in Wyoming the vehicle needs to be inside and the windshield warm before trying to reapply the mounting pad.
Also on the outside of the windshield with a marker mark the spot where the mirror goes. Other than the mark you have made if you can tell where it was the glass is not clean enough to reapply the mirror. |
Drive into a place that changes windshields. Ask them if they will glue your mirror back onto the windshield. Pay them less than what you would pay for one of those kits.
Done. I've been through this more than a few times and it finally suck through my thick skull. Those kits are worthless. |
Originally Posted by AJBert
(Post 705086)
Windshield
I live in California. I called a windshield place and they gave me a ridiculous price just to glue it back on. I'll do it myself. Thanks for all the information in your replies it will definitely help!
Good luck! I've had mine fall off twice on my truck. Make sure to clean not only the windshield, but the metal tab as well, as eshaw said above.
Knock on wood, the second time it seems to be holding! |
Originally Posted by Asantella
(Post 705127)
Slather on the gorilla glue and crank the heat on!
