Installed New Multifunction Switch, Now Nothing Works
I installed a new multifunction switch because the wiper switch was worn out. I made sure everything was exactly the way the old one was. Now I have several problems:
-No response when key is inserted/turned -Headlight switch: dash lights come on but headlights do not -New switch does not work whatsoever Any ideas on what it could be? The battery was disconnected and reconnected after installation. |
id check the fuses
All fuses are intact.
sounds like the ignition switch has a loose connection. Ya might wanna recheck your work.
(Post 546148)
I would think so... Does the cluster light up when the key is turned?
Not when the key is turned, only when the headlight switch is turned.
yea it really sounds like the ignition switch got knocked loose or something
Alrighty I'll check that out.
I agree with gio, sounds like a lose ignition switch connection.
| All times are GMT -5. The time now is 05:05 PM. |
