KEYLESS ENTRY
it will say in the RPO codes if u have keyless entry or not. if u do a search here u should find it. someone asked about that b4.
as for the the rear glass button check the rear latch. if thats good and u can open it w/ the key in back then its prolly in the wiring.
If you take the center console out every one I've seen has the brain for the keyless under it (little black box). I forget the RPO code for it but I'm sure its all over here if you search for keyless.
93Miata
24
Nov 14, 2005 10:09 PM
