LF tire stance vs RF tire stance
as i was installing my 1.5" wheel spacers on the front and TBAR crank to level the truck i have noticed that my LF tire stands out roughtly 1/2" more then my RF????
is the the way they designed the blazer, is it a know issue or designed that way.... really scratching my head here |
Check and see if your alignment is off. I adjusted my tbars and it played with the alignment causing my tires to chop and twist the belts.
Is your wheel alignment correct? It's possible that if the wheel alignment is off that one tire would appear tilted outward or inwards.
just had the allignment done, and its in the green and still off?
Not sure on that one. Maybe you chamber is off? I know some places won't check that if you don't ask. I know my rear axle sits off centre, or at least looks like it does lol.
A friends 2005 Jimmy is just like that and its mint with 80,000 Kilometers .
Originally Posted by Strangerock
(Post 692416)
