Lift Kit for 2000 Chevy Blazer LT
Looking for an inexpensive lift kit for my 2000 chevy blazer lt. anyone know where i can find one? or how to build one? thanks
Cheapest that's worth it, in my opinion, would be a body lift or a 2.5 rough country lift kit. Body lift is cheaper.
Cheapest cheapest would be a torsion key crank and 2" rear shackles, but your replacing front end suspension parts often then not. Christine did a mild lift with just control arms and shackles I believe, that's better then the torsion crank. |
DonL,
Thanks for the info. Yea I'm not sure which lift I should go with, the body lift sounds more reasonable but I hate looking at the frame underneath. Anyway, do you have any links for either lift? Also what did Christine do to the control arms and shackles? |
If you go to Amazon, that's wheres I've seen the body lift.
rough country suspensions is where I picked up my 2.5 lift kit. and I believe if you do a search on here for "mild suspension lift" you can find the one that christine did. |
Originally Posted by tylerlsmith
(Post 697084)
DonL,
Thanks for the info. Yea I'm not sure which lift I should go with, the body lift sounds more reasonable but I hate looking at the frame underneath. Anyway, do you have any links for either lift? Also what did Christine do to the control arms and shackles? But to answer you question; I used longer shackles in the rear, and installed the Rough Country upper control arms in the front along with a torsion-bar crank. With the new upper control arms the geometry for the upper ball joints is better. Also, the Rough Country upper control arms use Chevy 1/2 ton pick-up upper ball joints. I installed new longer shocks in the front (one of the OEM ones was bad anyway) but for the back because I have factory self-leveling shocks that you cannot get in extended lengths that are used with special rear springs, I installed extenders for the upper mounting points for the rear shocks. I found these on eBay. As for parts wearing out, after two years (done in 9-2016), this is what I've had to replace which might or might not be directly related to the lift:
Christine P.S. Regarding options for alternate upper control arms, Superlift used to sell some but apparently they no longer do. At the time I chose the RC ones since the installation instructions called for no other changes to the vehicle whereas the Superlift upper control arm installation required welding a new bracket for the upper attachment of the shocks. The Superlift upper control arms used the stock style ball joints. This information might be useful if you find a set of the Superlift arms. |
(Post 697093)
Wow, I must be getting famous (or infamous??). LOL A link to how I did my lift is in my signature below.
(Post 698329)
no link attached. can you reply with it again.
