-   General Chat (https://blazerforum.com/forum/general-chat-34/)
-   -   Manual T-case Shifter After 3" Body Lift (https://blazerforum.com/forum/general-chat-34/manual-t-case-shifter-after-3-body-lift-73441/)
91chevywt Sep 2, 2012 09:31 AM
I have a '94 Jimmy that I fitted with the NP231 T-case, using the stock blazer shifting mechanism. After doing a 3" body lift, the transfer case shifter sits very low in the console. While functional, it looks bad. Is there anything out there to extend the shifter up a bit?
neo71665 Sep 3, 2012 06:03 PM
What I done was cut it right above the threaded section, welded in 1/2 rigided pipe (electrican had it) and to extend the rod for the button I used a welding rod cut to length. I added 3 inches to mine and its about 1/2 to 1 inch taller than stock. I also had to bend it back a few degrees. I cut cut the pipe I welded, bent it back, welded it under where the rubber boot sits.
