Must have tools for DIY'ers
Old Mar 4, 2014 | 01:05 PM
justaguywithtools's Avatar
justaguywithtools is on a distinguished road
Default Must have tools for DIY'ers
lots of questions from members who want to do DIY driveability issues with no basic diagnostic tools to do them.
what are some of the must have's with all the common blazer quirks?
I believe a minimum would be:
1: basic code reader
one with a live data stream would be better.
2: a DVOM
a power probe would be even better, (combi voltmeter, circuit tester, test light)
3: fuel pressure tester.
Old Mar 7, 2014 | 12:45 PM
abig84's Avatar
sawzall, torch, cut off wheel. hammers, pry bars, bazoka
Old Mar 9, 2014 | 10:53 AM
1992ChevyBlazer's Avatar
1992ChevyBlazer is on a distinguished road
Compression tester,
Cylinder leak down tester, Air Compressor required
Code reader, OBD II will work for newer. if you can find one with ABS And supports OBD I with the adapters for cheap GO FOR IT!
Misc. Pullers 2-3 jaw.
Ball-Joint/Tie-Rod/Pitman Arm/Idler Arm service tools depending on how far you want to get into your rig
Grinder, Dremill, grease gun, obviously grease ha ha, Vise 6" or so. I got a harbor freight 12T press in my shed.. hardly ever use it.
Small torch (Walmart/Meijer) is what I use and it did fine on my u-joints
So I guess buy what you need as you need it.
Old Mar 9, 2014 | 08:15 PM
KM346's Avatar
KM346 will become famous soon enough
Not necessarily for blazer specific quirks but, Id say the two specialty tools i use the most in the shop are:
Ball joint press
Ft/lb torque wrench
Old Mar 9, 2014 | 11:46 PM
richphotos's Avatar
Hands, that have joints that you did not know about and are only unlock-able through cheat codes.
Old Mar 10, 2014 | 12:55 AM
Diaita's Avatar
Google.
As for tools... Scan tool and leak down tester. Vacuum pump.
dbaas
Aug 9, 2011 08:46 AM
m3ch
Sep 4, 2010 10:27 PM
MuddBunny84
Dec 29, 2009 02:13 PM
mike77
Jan 21, 2009 10:10 PM
Acer2428
May 31, 2006 02:16 PM
