-   General Chat (https://blazerforum.com/forum/general-chat-34/)
-   -   Need help (https://blazerforum.com/forum/general-chat-34/need-help-85544/)
XxEmokitty Apr 25, 2014 10:55 PM
Need help
My blazer starts but will shut right off and this only happens during the day when it's hot out. I've changed the thermostat cuz it was melted closed and it helped for awhile and now it's started up again. Also it use to be when you kept your foot on the gas it'd stay on but now as soon as you take your foot off it immediately cuts off. Please someone help me out.
Thanks.
Lancealot Apr 26, 2014 01:26 AM
Check codes etc. With what you gave it sounds like a possible idle air control valve issue. Also heat changes resistance and can effect failing sensors and poor wires and connections.
XxEmokitty Apr 26, 2014 08:48 AM
How do I do all this? I'm sorry I know nothing about cars or how to fix them but my boyfriend is a quick learner if it's easy to fix
Lancealot Apr 28, 2014 01:51 AM
Go to Autozone or other store and have codes read from the computer. If you can't get it there borrow a code reader from someone or use the loan a tool at a store that does that. First step is see what the computer tells you.
XxEmokitty Apr 28, 2014 09:30 AM
OK we will do that thank you
