Newbee
Old Nov 7, 2007 | 01:53 PM
4byluv's Avatar
4byluv is an unknown quantity at this point
Default Newbee
Hey there. New to the forum and have what is most likely a repeated question. (bear with me) What size is the axle nut on a 99 blazr? Changing my wheel hub tonight and want to make sure I have the tools I need.
Old Nov 7, 2007 | 04:28 PM
Zasder's Avatar
Zasder is an unknown quantity at this point
Default RE: Newbee
36m deep socket
Old Nov 7, 2007 | 07:24 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
Default RE: Newbee
Yep it is a 36mm deep socket. Should be able to rent it at Autozone or you local auto parts store. Should expect to put a $15-$20 deposit down for it, or just spend the <$20 to buy it.
Welcome to the forum. I assume you are about to tackle the ball joints or replacing the hub. Good luck with whatever job you are doing. And post up if you have any questions.
Old Nov 7, 2007 | 08:39 PM
quinnman105's Avatar
quinnman105 is an unknown quantity at this point
Default RE: Newbee
[sm=welcomesign.gif]to the forum. Ask questions if you have any.
Old Nov 8, 2007 | 02:35 AM
thegr81's Avatar
Default RE: Newbee
welcome to the forum! Any questions just ask!!!
Old Nov 8, 2007 | 07:19 AM
4byluv's Avatar
Default RE: Newbee
Thanks for the info. 36mm did the job. Replaced the pass. side hub without an major snags. The vibration from the bearing being bad sure did lock that axle nut on there pretty good though. I can't belive how quiet that truck is!
4byluv
Nov 10, 2007 09:48 AM
