It's a Duralast reman 140 amp
(Post 677401)
shoot I just seen your looking at a 99 tahoe, those are square body with a 5.7l... you need to be looking at the next gen body style sir...
the belt drive setup between the 4.3 and 5.7 is the same, it should still bolt up. double check the connector first before removing your old one
still believe you will need an inch longer belt
(Post 677429)
So maybe I'll be ok with this one? with $5 core it was $30.85 total. |
After reading youre posts...maybe 2day will be a good day after all!!
It's gonna work!!
Set both alternators side by side...measured all mounting points and no problem...only difference besides size is the plug has slightly different angle/orientation which will not be a problem. I'm very happy. Gonna stab motor & tranny back in on my weekend (Mon/Tues). In process of installing what I can and just generally getting ready.
TO EVERYONE THAT OFFERED ADVICE/HELP/INFORMATION I TRULY APPRECIATE YOUR EFFORTS AND THANK YOU ALL VERY MUCH! |
| All times are GMT -5. The time now is 06:41 PM. |
