PITA Replacement Job
I changed out my fuel filter today. The truck has 28,000 miles on it, so it was the first replacement filter. After jacking the left side up,scooting around under the frame rail, getting dripped on, putting the new filter in the holder backwards, I was really glad there were no leaks when I finished! Now I know why the dealer charges $70 to do the job (of course it's a lot easier for them). [:'(]
RE: PITA Replacement Job
lol you think the fuel filter is bad? Wait until you change the transmission fluid! They dont have drain plugs, you have to disconnect the exhaust and unscrew like 12 bolts (each bolt will drip fluid). By the time you get done, it looks like you slaughtered a steer in your driveway. Then you have to scrape the gasket off of the tranmission while it is still dripping on you. Then you get to scrape the pan and clean the magnet which is covered in a metal/oil paste! Its fun! PS. Do it when after you have driven around for about half an hour...its fun when hot oil runs down your arm! lol really though, it sucks. Probobly the worst filter on th blazer to change.
Yeah I did my fuel filter with my truck straddling the ditch at my parents way back when I first bought my Bravada. All of the connections came off relatively easily after I found the proper (odd) sized wrenches. Then I just used some penetrating oil to give me some lubricity in the holder.
And the transmission thing got easier in the subsequent years. I definitely recommend the installation of an add-on drain plug. |
ORIGINAL: swartlkk . And the transmission thing got easier in the subsequent years. I definitely recommend the installation of an add-on drain plug. |
| All times are GMT -5. The time now is 08:35 PM. |
