Priming your oil filter when you change your oil
Who else pre-fills the oil filter before putting it on? I do when possible.
i do when i can also
when I cant I lubricate the seal with oil |
lube the seal and let her go!!! i never fill them, never have and prolly never will, never had a problem yet.
never have i only lube the seal when i do the oil changes my self wich is seldom
I also lube the seal and pre fill the filter as well...fig it cant hurt.
Originally Posted by warthogdriver
(Post 520032)
Doesnt realy need to be done since the oil pump is in the bottom of the oil pan thats where the engine gets it priming.I lube the seal scre it on and thats it.Fire it up Go
About 7 or 8 years ago I did a course on a CAT Diesel engine. AT that time they said NOT to fill the oil filter because that puts un filtered oil in the engine.
Personally I never fill them unless it is a brand new engines first start. |
I lube the seal and generally call it good. Sometimes out of boredom on something with a vertical mount I'll dump a little in, but don't get super involved.
How do you prefill a filter that mounts sideways?
| All times are GMT -5. The time now is 10:39 AM. |
