question,are the 1998 thru 2002 the same
Old Sep 17, 2023 | 01:12 PM
int3414's Avatar
int3414 is on a distinguished road
Default question,are the 1998 thru 2002 the same
this is probably easy,i have a 2000 4 door blazer with a plow,will that plow fit on a 98 thru say...2002....i am looking for something that may not be all rotted out.thanks!!Rich
Old Sep 18, 2023 | 03:50 PM
El_Beautor's Avatar
If it bolts up on your 2000, then the plow should bolt up to any 4 door 4x4 Blazer/Jimmy from 98-2004. The frames are the same on all those. Some manufacturers only state up to 2002, but there's no structural differences in the S-series trucks from 2002-2004.
I think 95-97 are also the same, but stay away from the 95's due to them being a weird cross-over year for the engine and diagnostics.
It MAY bolt up to 4x4 2 doors. It MAY bolt up on a ZR2. It MAY also bolt up to a S-10 or Sonoma of the same years. You'll have to do some more research to know for sure.
Old Sep 19, 2023 | 03:13 PM
int3414's Avatar
thank you for that,maybe i can find one where the cab mounts aren't rotted off,,trans line rotten,or frame with large hole rotted out behind shackles,,or Ypipe pretty well shot..,to bad this thing runs really good....thanks again
Old Sep 20, 2023 | 06:54 PM
int3414's Avatar
forgot to mention, rusted brake lines and those fuel lines sitting on top of the frame...lol
bigbrody
Jan 29, 2017 09:00 AM
TAZ454
May 14, 2014 09:32 PM
Dean Davenport
Nov 17, 2013 01:13 PM
Travis_1203
Mar 24, 2013 11:58 AM
scottnettles
Mar 21, 2011 06:25 AM
