question,are the 1998 thru 2002 the same
this is probably easy,i have a 2000 4 door blazer with a plow,will that plow fit on a 98 thru say...2002....i am looking for something that may not be all rotted out.thanks!!Rich
If it bolts up on your 2000, then the plow should bolt up to any 4 door 4x4 Blazer/Jimmy from 98-2004. The frames are the same on all those. Some manufacturers only state up to 2002, but there's no structural differences in the S-series trucks from 2002-2004.
I think 95-97 are also the same, but stay away from the 95's due to them being a weird cross-over year for the engine and diagnostics. It MAY bolt up to 4x4 2 doors. It MAY bolt up on a ZR2. It MAY also bolt up to a S-10 or Sonoma of the same years. You'll have to do some more research to know for sure. |
thank you for that,maybe i can find one where the cab mounts aren't rotted off,,trans line rotten,or frame with large hole rotted out behind shackles,,or Ypipe pretty well shot..,to bad this thing runs really good....thanks again
forgot to mention, rusted brake lines and those fuel lines sitting on top of the frame...lol
| All times are GMT -5. The time now is 06:36 AM. |
