RE; Heat
while driving up a steep hill with the heater lever switched to the floor, the heat starts coming out of the vent.
when i level out, the heat comes back to the floor. what gives ????????? |
It most likely has nothing to do with the hill other than your engine is under more load to get you up the hill. There is a flaw in the vacuum system somewhere along the way. I would recommend checking all of your vacuum lines and replacing any that are dry, cracked, or brittle. It's not crazy expensive, just time consuming.
RE; Heater
thanks for your help.
:icon_wink: |
