Re; Radio clock
*Moved to 'General Chat'* The 'New Member' section is only for introducing yourself and your vehicle, not for asking for advice.
Without knowing which version of the radio you have, here are the directions for all three types.
Setting the Clock for Systems with the Set Button
Press SET. Within five seconds, press and hold the right SEEK arrow until the correct minute appears on the display. Press and hold the left SEEK arrow until the correct hour appears on the display.
Setting the Clock for Systems with HR and MN Buttons
Press and hold HR until the correct hour appears on the display. Press and hold MN until the correct minute appears on the display. To display the clock with the ignition off, press RECALL or HR/MN and the time will be displayed for a few seconds. There is an initial two-second delay before the clock goes into the time-set mode.
Setting the Clock for Systems with Radio Data System
Your radio may have a button marked with an H or HR to represent hours and an M, MN or MIN to represent minutes.
Press and hold the hour button until the correct hour appears. AM or PM will appear on the display for morning hours. Press and hold the minute button until the correct minute appears. The clock may be set with the ignition on or off.
To set the clock to the time of an FM station broadcasting Radio Data System (RDS) information, press and hold the hour and minute buttons at the same time for two seconds until UPDATED and the clock symbol appears on the display. If the time is not available from the station, NO UPDAT will appear on the display instead. RDS clock time is broadcast once a minute. Once you have tuned to an RDS broadcast station, it may take a few minutes for your clock time to update.
Rrryan
Aug 15, 2011 12:03 PM
dan_t
Nov 25, 2010 08:35 PM
Monkeyman
Oct 24, 2009 11:48 AM
artsound
Mar 8, 2008 11:09 AM
