RE; Switch placement
i am wiring up 4 spotlights under the front bumper to use as fog lights.
is there a good place to wire up the toggle switch in the dash area. i'e under the steering wheeel, left of it or right of it. is one area easier then the other????? :icon_hyper: |
What kinda of blazer we talkin about?
2nd gen - factory headlight switch panel is what I'm gonna do. Unless you have factory fogs then the fog button is in the way. |
well depends on if your 4 wheel drive or not. i have a 2wd so there is a nice place to put it where the 4wd switch would normally be. ive been planning on doin that myself
ive tried 2 different spots. the first one was below and to the right of the steering column. it was the junky swithc that came with the fog lights and started to melt on me. so i wired in a new one where the headlight switch is and it looks alot better than the first spot.
i would try right where the drivers left knee is, under the steering column....i have a kill switch to my radio mounted there and its pretty accessible but hidden at the same time.
I have the 2002 blazer with the 4.3
I will checkout the places you mentioned for the install. Thanks. Kennybopaloo. :icon_razz: 2002 blazer 4wd...................... |
Kennybopaloo, Put your vehicle information in your signature and attach it to your posts -OR- setup a 'garage' for your vehicle which will put the information below your screen name like many other people have. This will restrict the number of posts where people have to ask you for your information. Do this NOW!!
RE; Switch
i am not that sophisticated on the p/c.
i went to signature and wrote some info on my blazer. i could not do anything after that. thanks.... kennybopaloo.......... :icon_nic: |
That all you need brother!
