-   General Chat (https://blazerforum.com/forum/general-chat-34/)
-   -   Rear Backing Plates (https://blazerforum.com/forum/general-chat-34/rear-backing-plates-16559/)
jetrider Jan 23, 2008 12:24 PM
Rear Backing Plates
Anyone know where I can get both rear backing plates for a 2000 LT?
Chevy Lover Jan 23, 2008 06:54 PM
RE: Rear Backing Plates
It shouldn't be to hard to find backing plates. I got a set of backing plates for an '80 Malibu from my neighborhood aftermarket parts store.
blznlowxtreme Jan 23, 2008 08:10 PM
maybe im just slow but what exactly are you talking about when you say backing plates?
Chevy Lover Jan 23, 2008 08:58 PM
Backing plates are what the rear brake shoes are attatched to.
[IMG]local://upfiles/2910/25B4899C4DD940D2A99C4D74D5598C57.gif[/IMG]
lennyblazer Jan 23, 2008 09:08 PM
Gotcha, I was confused too, so I didn't post. I thought it was a wierd way of saying the rear bumper or something like that.
Zed Jan 23, 2008 09:14 PM
You do know that the rear end has to come apart and pull the pin out to get the axles out so you can changes the plates eh , it's actually a big job !
Mine came from the dealer ...
Zed
Chevy Lover Jan 23, 2008 10:35 PM
It took me 4 hours to replace 2 backing plates. I replaced both wheel cylinders and the brake shoes at the same time.
It's easier if it's not a locking diff 'cause you don't have to work with the blocks. Just remove the diff cover, remove the pinion lock bolt, remove the pinion shaft, slide the axle inwards and remove the "C" clip. Then remove the axle. Remove the rear brake shoes , wheel cylinder and park brake cable, remove the anchor pin.
Then put it all together, bleed and adjust the brakes, adjust the park brake cable and fill the diff..........ok, it's a lot of work :D
swartlkk Jan 24, 2008 07:59 AM
A 2000 will have rear disk brakes with an internal drum parking brake so things are a bit different than what is used on a true rear drum setup. But you still have to pull the axle shafts to get the backing plates off. It's not a particularly complicated job, but it is time consuming.
Chevy Lover Jan 24, 2008 01:16 PM
Yes disc or drum brakes, it's a very similar job.
Just out of curiousity what do you have on the rear, disc or drum. The reason I ask is that I see both options for the rear on a 2000 model.
