Cheap mods for the Blazer
Hey I am wondering if there are any cheap mods to do to the blazer that look good or function well and make it stand out a little more. Little things are awesome. Also they should be fairly easy to do. I am on a very cheap college budget, hince the cheap stipulation. Thanks all who reply.
Lenny
Lenny
RE: Cheap mods for the Blazer
I debadged my Jimmy by taking off the three 'Jimmy' emblems, blacked out the headlights, tail-lights and tinted the front windows to match the backs and rear-window. My truck is indigo blue so the blue/black combo looks awesome. I bet it would look just as good with red/black
Projector heads turns, tails, chrome fronts (grill),a nice pinstripe can make alot of difference, even drop kits are relatively cheap.
Well you can do the t-bar crank to the front end for absolutely nothing. Get some shackles for the rear and tada you're taller. Course you already knew that but.....
Headlights $120-170
Signals $30-60
Taillights$30- 90
High mount Brake light cover $10-20 (eBay only)
Signals $30-60
Taillights$30- 90
Wash and wax it.
Vacuum the interior.
Those two things make a huge difference. If a truck is clean, people notice it.
Debadgeing is cheap, free in most cases.
Cheap performance upgrades.
Cut off the restrictor on the butterfly.
Replace the factory muffler with a glasspack.
Install a better air filter or cold air intake, dry element.
More costly, but look cool.
Suspension lift or drop.
Tires and wheels to match.
Grill guard.
Lights, fog, driving.
Really the options are only limited by how well you shop for bargains and your mechanical skills (labor is free if your doing the work).
Grill guard.
I found some sport mirrors with turn signals on ebay for 40 bucks. Nice gloss black finish with white turn signals. It would pretty sharp. Thinking of getting them for myself.
ORIGINAL: Hanr3
Wash and wax it.
Wash and wax it.
-Lenny
I have removed the deflector off of the throttle body and am looking to put it back on. I really don't feel that it did anything but change the throttle tip in (ie. more response with less throttle). WOT didn't change at all and it seems that something is amiss with the distribution of the EGR gasses after this mod.
If you really want to do this, then only cut it down to around 3/8" to 1/4" tall. That will still help pull the EGR gasses to the rear of the plenum under normal cruising.
