rocker panel dent what should i do .......?
the title says it you don't see it the door dings from the ignorante ubanite pricks stick out more but it still bugs me how would a body shop fix it ?
I really can't see how they would get behind it . Bondo ? not for me < drill holes? eek the other thing is my year old KCs driving lamps are starting to rust suggestions ? I was thinking a bead blasting and armour /gun kote is in order. the other thing regardless of the undercoating I am starting to see surface rust at 2 years opinions , suggestions thanks all |
RE: rocker panel dent what should i do .......?
For the dent, a stud gun would probably be my first choice. Weld the studs on and pull the dent out. Then just grind them off when finished. If they cannot get to the back side, there will be some filler needed for a good repair.
thx i am leery of bondo
| All times are GMT -5. The time now is 03:03 PM. |
