Rust control
2003 Blazer, owned since 2005, low miles (85k). After looking around at possible replacements, I'm strongly inclined to invest some $ to rejuvenate this limo. Nothing else out there that would meet my needs (incl. 5k# towing). Other than a few minor repairs, my main concern is frame rust. Since this wagon sits most of the time, and I live in the snow belt, the frame has some rust on it, not critical yet, but I'd like to address it before that time comes.
Looking to find out what others have used. Any suggestions? |
Por 15
I agree with Doc. POR (paint over rust) 15 is an excellent product. Expensive but worth it. Follow the instructions to the letter and believe them when they say it does not come off skin.
Yup, POR 15 all the way.
Anyone ever used "Fluid Film"?
If your looking for a new life ?
1 Attachment(s)
I know the frame life is so important, nothing is worse to hear. But if your going pump real new life into you K5. Then it's body off and frame out , media blast, weld in reinforcements and problem areas, power coat and put it all back together. I know this isn't what you wanted to hear, but. . .
The sole reason I bought my K5 was I found it in West Texas, not a spot of rust on it. Looked like it was painted with a mop, but solid. It don't get any better that that ! :icon_dance-cpatch: |
Thanks for the responses. To those who have personally used POR 15, please comment on your results, difficulties, etc. Although it would be by far the most expensive "paint" I've ever used, if it works it's a bargain!
You could just take out the body mount bolts and lift the body5"- 6" and clean and use POR-15 on top and bottom ? Just a suggestion.
I have used por-15 many times and it works amazing. Did not have any hard time applying it.
There were a few places I did not even clean with a wire wheel, literally just painted over the rust. |
(Post 674160)
There were a few places I did not even clean with a wire wheel, literally just painted over the rust. I'll take a good look at potential rust issues- interesting that although there are a zillion of these on the road around these parts, there seems to be little, if any, body rust-through. In truth, there is nothing major, a coolant leak I haven't chased down yet, the "standard" 4.3 oil leak from the front of the engine, and a couple of other things. I do have a concern re brake pedal travel: mine, with a firm application and the engine running, goes just about to the carpet. This after lots and lots of bleeding. Think I'll start a new thread to find out if this is normal. |
