-   General Chat (https://blazerforum.com/forum/general-chat-34/)
-   -   Spot Lights in Front of Grille (https://blazerforum.com/forum/general-chat-34/spot-lights-front-grille-88854/)
ZEALER Feb 11, 2015 02:32 PM
2 Attachment(s)
Hi all,
I have a 2002 GMC Jimmy. I would like to install some small square 3" spot lights in front of my grille, much like this:
https://blazerforum.com/forum/attach...ine=1423686772
How would I attach my own to a similar effect as above? The grille is all plastic. I suppose I would have to make some brackets that connect elsewhere for structural support and reach down to the base of the grille.
How have others done this? Help me brainstorm.
Thanks!
lazyboyjake Feb 11, 2015 02:55 PM
I think the easiest way would be to drill holes in the bumper and just run a bolt through it. Unless you're trying to keep from doing that, then I guess you could go through the trouble of making your own bracket. Also, have you thought about using LED's? I'm personally in love with them since they use a lot less power and give equal to or more light than regular off road lights. Plus, I have never had to touch a relay since the LED's draw so little power.
ZEALER Feb 11, 2015 03:56 PM
Ya the lights I have in mind are in fact LED's.
Won't drilling through the plastic bumper cover still be too flimsy? That is my main concern with that idea.
lazyboyjake Feb 11, 2015 06:06 PM
What kind of road/trails are you going to be using this on? If it's not bumpy to the point where things on the inside are shaking then you should be fine.
TMR_BLAZER Feb 11, 2015 08:53 PM
I would just fab up a little "L" shaped bracket and go behind the grill and down to the core support or metal bumper
