-   General Chat (https://blazerforum.com/forum/general-chat-34/)
-   -   switching oil brands?? (https://blazerforum.com/forum/general-chat-34/switching-oil-brands-21902/)
mikeinwi 07-12-2008 12:13 PM
i currently use Q horsepower full synthetic and i would like to switch to mobil 1 synthetic now i know certain types of oil dont mix well, causing sludge build up etc., but does anyone know if i will run into any problems going from the q to mobil 1?
swartlkk 07-12-2008 12:28 PM
RE: switching oil brands??
I wouldn't worry one bit about it. Shouldn't have any issues.
mikeinwi 07-12-2008 12:31 PM
alright thanks..lol time to run the checker now
Kage0113 07-13-2008 11:40 PM
I wouldn't worry about it. you would get sludge going from conventional to synthetic but going from synthetic to synthetic you should be fine.
Good_Chevy 07-14-2008 10:22 PM
I also heard that if you switch to synthetic oil you can't go back to conventional oil because it'll screw up your gaskets from expansion and contraption, and you'll end up with a leek.
curse 07-15-2008 01:35 AM
So what if you dont know what was in it before? Is there a way to completely drain the previous oil?
swartlkk 07-15-2008 06:48 AM
That is another myth from the very beginning of synthetics. With the way oils are now, you can switch back and forth with no worries. I did it with my Bravada when I had a oil pan gasket leak. The leak was due to loosening bolts. The synthetic oil showed it to me and I switched back to dino juice so I wasn't wasting expensive oil. Fixed the leak and it was all good again. Switched back to synthetic and never looked back.
95Blzr 07-15-2008 07:34 PM
When I bought my car im assuming the owner before me used regular oilbecause of thecheapo fram filter. All my cars I get I switch to Mobil 1 Synthetic and a Mobil 1 or K&N Filter. Never Had a problem.
mikeinwi 07-15-2008 08:29 PM
thats exactly what im runnin now the mobil 1 with a k&n oil filter
