Thoughts about 2001 ZR2 build needed
We all have those friends that ask us to help them we say yes even if we shouldn't. My dilemma is that he bought a '51 Land Rover in Oregon. It runs and he would like to return to Denver without using the highways over about 8 days.
I have a 2001 ZR2 project that I would like to take and would like some input on what I should check. It's got 203,000 miles on it and was purchased from a tow lot auction. I am in the middle of changing the Y pipe and Cats to the Magnaflow version and will get a Gibson exhaust soon. I have to finish working thru the air injection system have found one bad check valve but everything checks good.. I have changed the LIM gasket and given it a fresh set of plugs, wires and cap and rotor. The radiator is new as the old one have many bent fins from the previous owners. My question is before I put 2400 miles with about 1200 being unpaved roads and trails. on it what should I look at? The trans will serviced and the tires replaced. If it helps it has a Specter CAI and Pacesetter headers. Just replaced the gaskets and installed Stage 8 header bolts with clips. Thanks in advance...just looking to benefit from the experience of others |
Originally Posted by 2001ZR2
(Post 687343)
I have a 2001 ZR2 project that I would like to take and would like some input on what I should check. It's got 203,000 miles on it and was purchased from a tow lot auction. I am in the middle of changing the Y pipe and Cats to the Magnaflow version and will get a Gibson exhaust soon. I have to finish working thru the air injection system have found one bad check valve but everything checks good.. I have changed the LIM gasket and given it a fresh set of plugs, wires and cap and rotor. The radiator is new as the old one have many bent fins from the previous owners. My question is before I put 2400 miles with about 1200 being unpaved roads and trails. on it what should I look at? The trans will serviced and the tires replaced. If it helps it has a Specter CAI and Pacesetter headers. Just replaced the gaskets and installed Stage 8 header bolts with clips. Thanks in advance...just looking to benefit from the experience of others Unless transmission is about to fail, I would think everything else that could fail would give you some warning. Here are some thoughts that come to me; mostly while thinking about what I would consider with a truck that was new to me with an unknown maintenance history:
Final advice: Have fun! |
Thanks Christine you are hitting on the points I am seeing.
I forgot to mention two things. The power steering pump was replaced shortly after I corrected the belt routing. They did a A/C removal and failed to look at the sticker on fan shroud. I added an idler pulley and found the bearing in the power steering pump was so bad that it would throw the belt. Turns out they didn't put back in the 3 bolts that hold it to the bracket. I made the same mistake they did and tightened up the back bracket nuts. I loosened them up and found I could put back in the bolts to the front bracket. When I did the LIM and radiator I replaced the hoses since the coolant had oil in it.. Which I know will attack the rubber so instead of finding myself on the side of the road I replaced them. The reason I am having the trans serviced is appears the trans has been changed out. I found a significant leak at the radiator connection. Apparently teflon tape and force can seal the line for a while. I prefer to use the clip as I am that anal. :icon_steer: Thanks again for the reply. |
(Post 687396)
The reason I am having the trans serviced is appears the trans has been changed out. I found a significant leak at the radiator connection. Apparently teflon tape and force can seal the line for a while. I prefer to use the clip as I am that anal. :icon_steer: Thanks again for the reply. Your leak of the tranny fluid at the radiator was a good one to address. I totally agree that the use of telfon tape for the connections is not a good fix. That could have been a catastrophic failure too! Your description of that reminded me of when I had decided to have the truck serviced at a local GM dealer and noticed while they had the truck up that although they were supposed to do a transmission flush they had missed that one of the metal transmission cooling lines had almost worn through where it was vibrating/bouncing against a sharp corner on the idler arm bracket. I was pretty pissed that they had not caught that. (I have since put on a piece of hose over that section of tubing to protect it.) That find, along with other disappointing work associated with that dealer had me realize that as much as I had hoped to put the years of breaking fingernails or at least getting grease under my fingernails behind me, if I wanted something done right, I'd have to do it myself! LOL Have fun on your trip! |
