-   General Chat (https://blazerforum.com/forum/general-chat-34/)
-   -   Torque specifacations (https://blazerforum.com/forum/general-chat-34/torque-specifacations-90844/)
johnnylovsey 09-29-2015 08:13 PM
I Have a 2003 Blazer L/S 4.3 liter any one out there help me with the torque spec,s on the upper intake manifold bolts and the valve cover bolts.
swartlkk 10-01-2015 11:36 AM
rThe values you are requesting have been requested and provided in past threads. A quick search for either "intake+manifold+torque" or "valve+cover+toque" (without the quotes) will turn up the relevant threads/information.
nomoresubies 04-22-2021 05:13 PM
Tried that. Getting nowhere....
Vahomboy 04-23-2021 09:06 AM
See this thread, post 14.
Lower intake gasket replacement - Blazer Forum - Chevy Blazer Forums,
Install the manifold and bolts and tighten the bolts in this sequence:
https://blazerforum.com/forum/attach...ent-188150.gif
Tighten the bolts in sequence to 26 inch pounds (some versions of the factory manuals say 27 inch pounds, but I doubt 1 inch pound difference matters).
Then tighten the bolts in sequence to 106 inch pounds.
Then tighten the bolts in sequence to 132 inch pounds (11 foot pounds).
This is a job for the 1/4 drive "inch pound" torque wrench.
nomoresubies 04-23-2021 10:36 AM
Thanks for all that information but the search for torquing the intake manifold was just an example in the previous post. I was looking for u-joint and pinion nut specs. I posted here because I did a fair amount of searching in the forums with various keywords and just couldn't come up with anything. I got some specs from the net and wound up snapping a u-joint bolt so had to remove the pinion flange to remove it. Now I need to torque that back on...
swartlkk 04-24-2021 07:57 AM
Considering this thread is over 5 years old and has been answered to the extent necessary on the topic it was originally created for, it will be closed.
