Tow hitch
Last weekend I bout a Reese tow power rear tow hitch for my 96 four door blazer. The box said it fit s10s. I don't see how I can even mount the thing nvm have it able to hold any weight. Has anybody else had any experience with this hitch on their blazers. Or any ideas how to mount it
i wonder if its for a pick up truck s10 maybe? i know my k5 hitch wouldnt work on my k30 due to it being different
Probably supposed to be for the truck. I just don't wanna be out the money and have a hellofa paper weight
are you any good at fabricating? cause you could make it work.
Im thinking i can probably grind it down to fit in the three holes that I've seen them mounted into on a lot of other applications. Not planning on doing any serious towing, mainly just a tow point incase i ever get stuck nose first, and some minor towing if I ever have to
whats the part number you got?
2 Attachment(s)
It can be made to work but its a bit of work including cutting the hitch and possibly your bumper to make it work. There is a difference in the 95-96 blazer tow hitch from the s10 and 97 on cause of the bumpers. The 95-96 blazers came with a roll pan style bumper and the hitch will bolt to the outside of the frame rails. Where as the s10 and 97 on bumpers are a step bumper and the hitch sits on top of the frame rails and uses the bumper bolts to hold it on. My suggestion would be return it if possible or sell it and buy the correct hitch. I'm speaking from personal experience on this:(
95-96 hitch https://blazerforum.com/forum/attach...ine=1361045075 S10 and 97 on blazer hitch https://blazerforum.com/forum/attach...ine=1361045075 Notice the difference in the ears that attach to the frame? |
i might just have to take a loss and buy the new one. No way ill be able to even break even on the deal, and I doubt the possibility of return. I do appreciate the advice though.
Rex, I do see the difference, and didn't think anything about it when i bought the hitch that I did |
this is the one that i bought. |
(Post 568262)
95-96 hitch https://blazerforum.com/forum/attach...ine=1361045075 S10 and 97 on blazer hitch https://blazerforum.com/forum/attach...ine=1361045075 Notice the difference in the ears that attach to the frame? I used a reese 33021 hitch on my 2000 4x4.. looks like this... got it from the junkyard for $50 http://www.hitchanything.com/images/...s-33021-32.jpg |
| All times are GMT -5. The time now is 10:15 PM. |
