transfer case help < Quick responce
I can get my hands on a used transfer case FROM a ZR2 blazer 2000, 4 switch 4x4 for $200. Now all i need from is is the shift motor for my regular Jimmy SLS 4 switch 2002. Will this transfer case fit in my truck? or better yet will this shift motor fit on my transfer case? |
RE: transfer case help < Quick responce
Provided the transfer cases are the same (check the numbers on the tag located at the back of the transfer case), the encoder motor should swap over. Hope it works out for you..
