what happened to my springs????
RE: what happened to my springs????
the gremlins took them?
Someone fed them after midnight again...
I'm going to take a stab in the dark and say you bought the truck this way? Looks like someone did a cheap a$$ lowering job to me.
actually i bought the truck bone stock and im having a friend put my air ride in def not a cheap way of lowering it
Bout time man LOL!! Looking good man I can smell the sparks that you will be throwing soon, I just drug all over a ranger that was fully bagged but didn't lay any frame tonight LOL!!! :D
Man I hope you guys have better luck with bags than I have. I had to replace 'em all on my Range Rover, got so fed up with em failing that I just swapped em out for coils and shocks. The bags seem to only last so long, and NC temperature changes don't seem to make the bags last any longer.
Air Ride ain't everything it's cracked up to be on a 4-wheeler [>:] |
Are you going to notch the rear? What setup you going with?
Make sure you post tons of pixs. |
off topic...but does anyone use magnesium when they drag?
test
well i have new pics but i cant post them
What bags are you running?
firestones 2500 and 2600
That looks nice. How did you do the back end?
Any pics of the rear end? |
4 linked and notched completly stock interior
Got any more pics?
Got some interior pix? did you just do the bolt in notch?
i'm waiting for some nice weather to take pics unfortunitly my little sister backed into the truck today and smashed in my tailgate so now i have to fix that also
no bolt in parts all custom made at a hotrod shop called Pyscho Kustoms in Cranston RI |
heres some pics i took today i still need to clean up the interior before i take any shots of inside
http://i78.photobucket.com/albums/j1...s/IMG_0199.jpg [IMG]http://i78.photobucket.com/albums/j1...s/IMG_0198.jpg[/IMG] [IMG]http://i78.photobucket.com/albums/j1...s/IMG_0197.jpghttp://i78.photobucket.com/albums/j1...s/IMG_0195.jpg And heres my newest addition my little sister was in a hurry to leave and didnt look behind her car http://i78.photobucket.com/albums/j1...s/IMG_0196.jpg |
I don't think that she would have lived to tell about it.
that sucks, but it does look good.
Do you lay frame? |
no the shocks in the rear keep it from laying and my control arms hit the frame in the front
that sucks with all of those dents, regardless it still looks sweet!
You need to do a s-10 truck front brake swap and use drop spindles to lay the front out and even on 18's you need to notch the front part of the frame for the steering unless you get the no notch steering linkage!! I did the brake swap using the front rotors, pads and calipers off a s-10 truck same year as mine then threw all that on drop spindles from aim and one thing to mention is that you can use the blazer brake line you just need to take and round off the squared edges on the end that connects to the caliper so there wont be any leaks!! I have my front done that way (except the steering linkage, haven't gotten to that yet but I lay crossmember)!!
i have drop spindle the control arms are holding me up right now
in all honesty im pretty happy wity how low it is it may not lay frame but it looks good and i have everything still stock no removed inner fenders no raised floor i may relocate everything under the hood in the future and lay it out but for now im happy |
The front you can still lay out with everything in the stock position on 18's with a 35 series tire when I get the chance I will take some pics of my front for you so you can see that there isn't that much you have to cut to lay the front out, I have factory control arms and I just trimmed litterally the front out a lil extra and it layed mine out on 18's with a 40 series tire. I do have to say though yours does look really good where its at!!!:D
wait till i get it back from the body shop just waiting for my appraisal
