Where is the block heater?!?
I have a 98 zr2 blazer and I can't seem to find the block heater. Is there a good chance that it might not even have one? Where are they located so I can check for sure? Thanks.
block heaters are extras possibly yours dont have 1 unless a previous owner has requested it when he bought the truck
So if there is one, where would it be located?
if its was added at the factory i believe it is attached to one of the freeze plugs on the drivers side. Not positive though i would have to look at mine. There is a very good chance you dont have one. The majority of them dont unless they were sold to a cold climate area. Mine was originally sold in canada which is why i have one.
id check near the grill or the wheel wells under the hood
You gotta put one in like I did. :icon_wink:
The line above the oil lines is for the block heater. You knock out the driver side freeze plug & install it there, then just run the plug out by the grill. This is the '00 Jimmy engine I put in my '89 S10 Blazer: http://i297.photobucket.com/albums/m...lockheater.jpg http://i297.photobucket.com/albums/m...nginemount.jpg |
| All times are GMT -5. The time now is 03:56 PM. |
