-   General Chat (https://blazerforum.com/forum/general-chat-34/)
-   -   where can i get replacement Distributor Cap screws? (https://blazerforum.com/forum/general-chat-34/where-can-i-get-replacement-distributor-cap-screws-75056/)
Antbankz 11-09-2012 03:23 AM
1 Attachment(s)
i lost one of the hardware screws for the Distributor Cap, i believe its a torq screw(star shaped) either t-15 or t-20 (can someone confirm?) anyway where can i get a replacement screw or can i match it at hardware store?
no auto parts stores sell it by itself...and i dont feel like purchasing a new cap for $25-35 just for the screw considering the one i have is less than a year old.
Attachment 32241
4X4GS10B 11-09-2012 06:12 AM
Junk yard?
4X4GS10B 11-09-2012 06:13 AM
most rotor buttons come with replacement screws for it and the distributor cap and it's a lot cheaper than buying the cap
mmmrodge 11-09-2012 06:51 AM
x2 bone yard
Antbankz 11-09-2012 12:53 PM
rotors screws are slightly smaller (t-15)
thanks guys i will hit up my local pick a part this weekend and hopefully get lucky, on a side note.. found a video from 1aAuto and it is a t-20 bit
dbelcourt 04-02-2019 05:13 AM
Hi, I got the cap and rotor off my 1995 Blazer. It was a royal PIA, can't belive they come up with this design. I've got new ACDelco parts on order and should get them by end of week.
I looked at a few YouTube and it's obvious that the intake is better suited on later years. On this 95, there is no way to get any common torx driver/adapter. Part of the intake covers the engine side cap screw and 1/4" extension can't clear.
I'm thinking if I replace the screw(s) with a Phillips head I'll be able to slip a skinny screwdriver or bend one to fit. Alternatively a more common hex/Allen might also work. Anyone else tried this on a 95? I don't think I'll be able to reinstall the T20's the way I got them out.
I missed the days when caps were held with spring loaded hooks and a 1/4 turn with a flat head was all it took. :-(
eshaw 04-02-2019 08:29 AM
I had a 95. You can get drivers with flexible shafts that look like a wound spring. They work well for stuff like this.
dbelcourt 04-03-2019 08:36 PM
Thanks for the suggestion. I didn't think that would fit either. I'll pick one up and try it. Still hate torx screws!
Wyldmyn 04-05-2019 06:37 PM
I have a 95 Blazer and to get the torx out front closest to fire wall I use a 1/4 inch torx head with the 2inch extension and ratchet. It's easier to leave the ratchet off then u get some room to get to the torx head.
Trukntigger 04-05-2019 09:22 PM
Cheap set of wobble extensions works wonders.
