where is my coolant going?
Hi..I just put coolant in the overflow three days ago and it gone again! I'm getting ready to go on a road cruise 2200 miles and need to find out whats going on. the heater works, the water pumps seems to be fine, no whining no sloppyness, belts are good, cant see any obvious issues with the hoses oil is clear transmission fluid is clear Any suggestions would be appreciated
It's either leaking onto the ground, or into the engine. You said the oil looked good, have you noticed any white smoke coming from the exhaust?
It's most likely leaking externally. Do a really good check for leaks, watch under the truck when you park it, etc |
coolant leak
no smoke! I think it maybe the lines between the overflow and the radiator?? its really hard to see, i can see some moisture near the bottom of the radiator on the frame. I've only had the vehicle for 6 months only 140,000 miles on it
Originally Posted by cleburne red
(Post 705897)
If your oil looks good, you can still have a leak into the top of the engine. Hopefully, it is not a failure of the lower intake manifold (LIM) gaskets. To check for leaks, it may be necessary to pressurize the system with a hand pump at the radiator cap. This can help find small leaks like pin-holes.
thank you
(Post 705905)
(Post 705912)
Wouldn't the coolant eventually make it's way into the bottom end, and be visible on the dipstick if the LIM gaskets were leaking? Or is it such a small leak, that it doesn't show up?
If we're being hypothetical, coolant could be boiling off too, or else being sprayed into the engine compartment and then evaporating without being noticed.
If you're planning a 2200-mile road trip and can't find where it's leaking from, it might be time to admit defeat and take it into a shop where it can be looked at. Even if it's something like the intake manifold gaskets (a pretty good guess on these) or radiator (another good one) it's going to be cheaper and easier to fix it beforehand even if you have to pay someone. |
Coolant cannot be seen with the naked eye when looking at your oil, dipstick, or whatever.
A lot of times the "chocolate milky" substance people mistake for coolant is actually water. But yes, coolant could also be leaking. I work in an oil lab,we test both new and used oil. Water and coolant in used oil gets an immediate phone call to the customer. In this situation, I would take it in. Let them check it out, print out what's wrong, and go to the parts store to buy whats on the list. |
