Who has taken off their roof rack?
Old Nov 8, 2009 | 07:17 PM
Brian_D's Avatar
ill prob remove mine when i get the whole truck painted.. get it all done proper..
Old Nov 10, 2009 | 09:12 PM
Zeeke98's Avatar
Zeeke98 is on a distinguished road
I can't believe how many of you are bashing on unbolting the rack and putting the bolts back in. It really cleans it up and is a free mod. Sure if you want to do it right, you'd pull the inserts out of the roof from the inside and weld the holes up. I pulled it off my Jimmy when I sold it to my dad and I yanked the rack off 03 Blazer 2 door as soon as I got it home. I put some gasket sealer on the hole and put the bolts back in on mine and no issues. I didn't put anything on dad's, just put the bolts back in and no issues. The holes aren't water proof even with the rack on there. Water gets under the gaskets and the bolt holes are open on top for water to just sit and collect there.
Old Nov 27, 2009 | 08:43 AM
blazerJim1701's Avatar
blazerJim1701 is an unknown quantity at this point
Still not liking my roof rack, gonna take it off proper this time.
My question is, if I forgo putting the screws back in but filling up the holes with JB weld OR silicone sealer...
OR
http://www.jbweld.net/products/water.php
Then getting the same exact color touch up paint....
which is better option?
Old Nov 27, 2009 | 09:50 AM
Sisk's Avatar
I wasn't bashing leaving the bolts in. I understand not everyone can or will be able to weld over the holes and paint their entire truck again. I was simply saying you should seal it IMO to prevent any possible leaking.
Old Nov 27, 2009 | 10:00 AM
Zeeke98's Avatar
OR
Don't bastardize it like that with JB weld. Just silicone seal the bolts and put them back in unless you're going to pull out the inserts from inside the vehicle and weld the holes up. The inserts that the bolts thread into still stick up above the roof skin slightly so even if you do slather some JB weld on it, you'll still have raised bumps that will look lame.
Old Nov 27, 2009 | 08:29 PM
I put the jb weld on and it looks better than the screws in the holes, albeit the jbweld is whiteish but that is ok until I paint them.
The important thing is that the screw holes and where the screw hold are in the metal are totally covered up so no water gets in.
Now they look like bumps but are smooth and sealed and lower profile than with the screws in...
Old Nov 28, 2009 | 12:59 AM
gmc004x4's Avatar
gmc004x4 is on a distinguished road
i took mine off and have never had a leak. i do not think the holes go all the way. they are just incerts. i painted mine black to blend in with my truck until can get them shaved and painted. i look so much better with out it. yeah how many people had to take them off to paint them anyways. leave them off. if you cant fit it inside do you really need it?
Old Nov 28, 2009 | 02:15 AM
ABN31B's Avatar
I'm with lenny. pulled mine and slapped a third rail on to better support my rack
Old Nov 28, 2009 | 06:13 AM
Sisk's Avatar
I like the look of the roof rack. That's why mine will be staying on. But that's just me. Can't say I've ever used it (and probably never will) but it looks good IMO.
Old Nov 28, 2009 | 07:44 AM
I got used to my 1995 Blazer ( my uncles then he passed then it was mine) and it didn't have a RR on it.
I like the look of no RR, sleaker...
I won't be getting it shaved and painted, I'll be painting the area's that need painting.
As long as it looks good and no leaks...
