General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
1991 Blazer idles rough Code 33 is showing
Old Sep 23, 2006 | 08:56 PM
91Blazerblk's Avatar
91Blazerblk is an unknown quantity at this point
Default 1991 Blazer idles rough Code 33 is showing
My 1991 Blazer S-10 w/4.3 TBI idles pretty rough especially when you first start it up. I just ran a diagnostic check using a jumper wire as shown at http://www.troublecodes.net/GM/
The service engine light flashed three times...paused then flashed three more times indicating a code 33 --- (MAP sensor signal voltage was too high (low vacuum) for 5 seconds when throttle opening was under 4%). Does this mean I should replace the MAP sensor?
Old Sep 24, 2006 | 01:47 PM
ShadowHawk's Avatar
ShadowHawk is an unknown quantity at this point
Default RE: 1991 Blazer idles rough Code 33 is showing
Not necessarily. Be sure to check all the vacuum lines under the hood. My Blazer is a '95, and I had to replace all the vacuum lines 1.5 years ago - as they were all cracked, leaking, and falling apart.
G'Luck!
Rex S.
Old Sep 25, 2006 | 03:23 AM
I already had to do that a few weeks ago. Some of the lines were actually falling apart. I disconnected the battery to clear the codes, and 33 is now the only one left.
TheRandom1
Feb 9, 2012 01:45 PM
nhguy261
Dec 30, 2010 01:41 PM
1oldK5
Apr 4, 2010 10:03 PM
Brooklin67s
Nov 1, 2009 02:11 PM
kiwiblazer
May 10, 2009 05:35 PM
