2001 blazer klik in 2wd
2001 will not come out of 4wd without kliking in front drive shaft
RE: 2001 blazer klik in 2wd
welcome...you have 1 or more of the following:
different size tires front to rear, a flat tire or very underinflated tire, 2 new tires and 2 very worn tires (effectively the same as 2 different sized tires) front differential gearset is a different ratio then the rear the front axle actuator cable is "hanging up" or sticking the vacuum switch on the top of the t-case is sticking. Those are the ONLY things that I have seen or can think of that can cause this condition. Let me know what you find or determine please. |
when my 2001 blazer is in 2wd my front drive shaft kliks and speeds up as the truck speeds up. it does not klik in 4wd.also, if i turn the front drive shaft by hand it makes the kliking sound (in 2wd) ps how far should i drive in 4hi
ORIGINAL: wormburnr when my 2001 blazer is in 2wd my front drive shaft kliks and speeds up as the truck speeds up. it does not klik in 4wd.also, if i turn the front drive shaft by hand it makes the kliking sound (in 2wd) ps how far should i drive in 4hi |
| All times are GMT -5. The time now is 02:21 PM. |
