-   General Tech Help (https://blazerforum.com/forum/general-tech-help-7/)
-   -   4wd fuse blowing (https://blazerforum.com/forum/general-tech-help-7/4wd-fuse-blowing-6906/)
mrblonde108 11-28-2006 12:44 AM
4wd fuse blowing
As soon as i hit the 4wd button i hear the fuse blow. I checked under the truck and i don't see any frayed wire. DOes anyone have an idea where the problem is??
thank you,
Brett
rooster 11-28-2006 01:18 AM
RE: 4wd fuse blowing
make sure u have the correct fuse installed od try installing a larger fuse in its place
mellon101 11-28-2006 01:32 AM
although I don't know what would cause your problem ....installing a larger fuse could lead to a pretty bonfire where your truck used to be. i dont think i would go that route.
rooster 11-28-2006 02:20 AM
wow i quess ive been lucky, its different but my speaker system was always blowing the inline 15 fuse so i went with a 20 and no more blown fuse for yrs.
hillbillyinOhio 11-28-2006 10:56 AM
your 4wd switch is bad. I have had this identical problem on two different blazers. if it is a second gen blazer, that be your problem. I guarantee. Get one from a dealer, only 30 bucks.
