General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
4WD not engaging....
Old May 22, 2006 | 03:55 PM
Jeremy_87_S10's Avatar
Jeremy_87_S10 is an unknown quantity at this point
Default 4WD not engaging....
I took my blazer to the trail for the first time yesterday. When I got to the first obsticle I had to turn arround when I started to climb arround the first rock my rear driver side wheel started spinning. I put it back in two wheel drive and started spinning out in the same spot as when I was in 4 low. Where should I check first. It doesn't have manual locking hubs, ant the lights dont come on on the indicators either.
Old May 22, 2006 | 05:34 PM
Default RE: 4WD not engaging....
I don't know why my sig isn't coming up but its an 87 S-10, 2.8 EFI
Old May 22, 2006 | 06:21 PM
4lowlife's Avatar
Where you engaging 4lo correctly? You did not state if 4Hi works.
Old May 22, 2006 | 06:28 PM
Tried 4 hi and low, no front drive on either. 4 low puts the rear into low though. I couldn't find any linkage near the hubs is it engeged at the diff? is it vaccume or electric. if its vaccume where does it come from?
Old May 22, 2006 | 06:30 PM
quontush's Avatar
quontush is an unknown quantity at this point
its vacume, i dont know aobut an 87, but a 95 its under the batterie, mybe that might help you
Old May 22, 2006 | 06:44 PM
well that was easy! The vacume line had fallen off the actuator. Wish I found that at the trail. The indicator lights still dont work though.
Old May 22, 2006 | 07:45 PM
quontush's Avatar
were was it located?
Old May 22, 2006 | 08:09 PM
right next to the battery. front of the pass. side wheel well.
Old May 22, 2006 | 10:16 PM
4lowlife's Avatar
4lo rocks!
seriosbrad
Nov 7, 2015 09:08 PM
chrisblaze
Dec 6, 2009 12:27 AM
GregNY
Jan 19, 2009 06:39 PM
Doverman454
Nov 29, 2008 01:45 PM
zombiebebop
Engine & Internal
Dec 8, 2006 03:15 PM
