4x4 Help
Hey guys. I have a 96 blazer 4.3 push button 4x4. It has about 175k miles on it and I have never had much problem from it all. I will post pix sometime. Can someone help me with my four wheel drive? It is push button and Its not working. I thought it may be the actuator or a hose, can anyone help me find out what to look for or anything at all??Thanks
RE: Hello Everyone. Help?
put in park, switch it to 4x4, then go - mine does that in my 92. if not, it might be the transfer case.
ORIGINAL: boomtruck97 put in park, switch it to 4x4, then go |
I've moved your post to the appropriate area.
ORIGINAL: m00nwater I've moved your post to the appropriate area. |
When you hit the button what happens? does the light blink on it but then switch back to 2wd? if so it might just be an encoder motor, which is what I had. I tried everything to get it into gear with no luck. thats what it turned out to be in the end.
The buttons and lights seen to work. It goes into 4 high and low and stays, and it gears lower. But the front wheels arent turning for sure.
mine is push button. i hadnt seen a 1992 with electronic transfer case and digital dash until this one. i like it though.
The buttons and lights seen to work. It goes into 4 high and low and stays, and it gears lower. But the front wheels arent turning for sure. |
Thanks man. I was thinking it was that, I just wasn't sure what to look for. You've given me some great info to start. Ill let you know. Thanks again
