93 manual blazer mulit problems
Ok i put in a new clutch, now the Spedomoter dosnt work, 4x4 flor console says im in 4x4 low ( im not) and I think i have this one right... Reverse sucks to get into.. I have to put it in first to use reverse Or shut it off and then switch Becuse it grinds. But that could be a bubble or two in ther hydraulic line right? Oh and my dash lights dont work. Also if im in second ill pop into nutrul sometimes.
Could i have done something while puting everything back together? Atleast it runs Kyle |
RE: 93 manual blazer mulit problems
check wiring, check fuses,a couple of those things sound like fuese are bad, but that's just my $.02
Nope checked the fuses and wireing (the stuff i un hooked) Didnt see any thing wrong. On the tansfer theres the three tubes if those get put on backwards would that be a problem?
Oh i have a horn now! |
would it be easier to jus get a set of gauges ?? would like to fix the original ones though
bump
Could be the one. A friend of mine had some work done and they got those hoses wrong and his 4x4 did not work properly...when they rotated it and got it back working again...so I would definetly check that...
